fuel pressure regulator
and so does my fuel tank. With a in tank pump,Do i need a pressure regulator?
If I do need one any suggestioN.
Thanks John
F-bodies regulate at the tank, and aftermarket systems usually have a feed and return with a reg. on the return side.
I guess the question would be is what are you going to use on the engine side.. what engine and fuel rail ?.. does it have one already ?
But in general, a regulator is required somewhere in the system as well as the return, If the Truck intake doesn't have requlator on the fuel rail.. then you will need to put one somewhere in the system, a aftermarket bypass regulator with a return line or what many have used is the 99+ Vette regulator/filter. I used on above the rear end and that way I only needed to run a feel line to the fuel rail.
You also need to consider the pickup in the gas tank, it needs to be baffled in oder to avoid starvation.
