Accessory Brackets
Old Jan 7, 2008 | 05:13 PM
Monte83's Avatar
Default Accessory Brackets
I have an LQ4 for my '83 Monte Carlo. I want to only use the alternator and power steering pump with reservoir (alternator on the passenger side, power steering pump on the driver side). Does anyone (factory or after-market) make accessory brackets for this combination, if so who? Any recommendations?
Old Jan 8, 2008 | 11:22 AM
Carshopinc.com's Avatar
LS1TECH Sponsor
I manufacture a alternator relocation kit that can be used in conjunction with the stock power steering pump to achieve this. I mount the alternator infront of the passenger head and use a aftermarket tensioner. This would allow the use of the stock f body pump and eliminate and down low clearance issues.
http://carshop.carshopinc.com/produc..._id/88927/9998
I can do the kit for less than the listed price as we will not be needing to use my idlers when run with a stock pump.
Old Jan 9, 2008 | 07:33 PM
jomomma's Avatar
street&performance also has kits like what you want.
