Tire size & gear ratio
Dave in Dallas
david@coolingpro.net
GR*Spd*168/(TD/2)*OD = RPM
GR= Gear Ratio
Spd = Speed you want to know the RPM for
TD = Tire Diameter
OD = Overdrive ratio, for 4L60E is it .7 for the 6 spd it is .5 for top gear.
RPM = RPM
So for your case: 3.73 * 65 * 168 / (26/2) * .7 = 2193.24 RPM
If you want to know your RPM in 3rd gear, just don't do the final caculation or use 1 for your OD value. I built a simple spreadsheet in Excel that enables me to experiment with different values.
Hope that helps
Pat
