? about Radiator
Old Jan 22, 2008 | 12:09 AM
ttyner1212's Avatar
Default ? about Radiator
i am doing the ls1 swap into a 93 240sx hatch and idk which radiator to use i have seen some using the koyo with altima fans but idk which radiator i need if it needs to be for a 240 or what
Old Jan 22, 2008 | 09:30 PM
SirWarrior's Avatar
koyo will work
I've seen most of the Schassis guys here use them.
Old Feb 10, 2008 | 05:25 PM
SonnyG's Avatar
Thumbs up Which radiator to use.....
You can use either an s13/s14 radiator from a k series car....
But,,,,,,,,The s13 bolts right in no problem...whereas the s14 needs slight modification.......Try to make sure you get a dual pass rad,,with 2 or more rows...Ebay sells alot of single row rads that look nice.....
You will spend quite some time finding a rad hose that fits without crimpage/blockage....alot of people have used braided s.s hoses cut to spec and used heatwrap on it to keep it kool.....
