advanced wiring questions 98 vs 99+ (speartech, help please)
I know the 99+ has no wire for the temp gauge, but thats not a big deal i do not think.
I have not compared pinout for pinout, but anybody have a "ITS NOT POSSIBLE" and a reason why, before i waste my time looking into this.
Thanks.
Ryan.
If you retain your 98 engine/pcm/dash harness your coolant temp will still work on the dash, the 98 sensor is 3 wire where as the 99 is 2. On the 98, it just has an extra wire that has a dif signal that goes directly to your dash.
Your fuel level gauge will not work. The 98 has the 0-90 ohm gauge and the 99+ has the 40-240 ohm sender. The 98 gauge cluster requires a formatted signal from the PCM. The 99 cluster I'm not sure how it works, I don't recall but I know john posted about this before in one of my threads.
You might have some other misc fuling issues like tank pressure sender and EVAP. 98/99 have different tank/evap setups.
You will have to do a lot of tricky rewiring at the PCM harness.. might be easier to just buy a 99 harness/pcm combo. Easier, or perhaps more trusted.
As far as engine function goes, it will work fine. I've done 3 of these, but they were swap related, so all of the vehicle details didn't matter.
I think you will have to change the instrument cluster to a 99^ also. 98 was the last year of the temp gage actually getting its signal from a sending unit. After that it is just a serial data feed from the PCM. This requires a serial data line being fed to the new instrument cluster instead of the sending unit wire.
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
