EFILive, to remove VATS and tune?
Old Jan 30, 2008 | 08:04 AM
garys 68's Avatar
Default EFILive, to remove VATS and tune?
I'm planning on putting an 2002 vette LS1 into a 68 vette.
I was told by a friend with EFILive that that program could remove VATS, unused sensors, and tune the EFI fuel/spark.
Will that program work for removing the VATS and sensors. I want to be able to use the OBD port without a half dozen codes showing up every time since I wont have rear O2 sensors, tank pressure, VSS, etc...
Old Jan 30, 2008 | 08:25 AM
Schwanke Engines's Avatar
LS1TECH Sponsor
Yes, EFI Live will do that for you. If you need help, we are here for you.
Old Jan 30, 2008 | 08:35 AM
garys 68's Avatar
I dont mean to cost you business, I was going to send the computer to you for reprogramming.
But a friend of mine reccomended EFILive so I could do it myself and have the ability to tune later.
Thanks for the info. I'll keep you guys in mind for the other stuff I need.
Gary
Old Jan 30, 2008 | 08:43 AM
LS1TECH Sponsor
No, thats ok. I would rather have people learning how to do things. I can still help you out with all the rest of the stuff.
