Will this fan wiring with 2 relays work?
Old Jan 30, 2008 | 04:52 PM
rockytopper's Avatar
Default Will this fan wiring with 2 relays work?
I purchased a stand alone wiring fuse and relay junction box. Refer to page 3of this link.
http://www.goindesign.com/ebay/SA1000.pdf
It has only 2 fan relays in the circuit. The stock set up uses 3 relays. Will this do te trick for me as it is with 2 relays only? please advise.
Old Jan 30, 2008 | 04:55 PM
LS1MCSS's Avatar
I would use three relays and the schematic in the sticky. It's proven to work.
https://ls1tech.com/forums/showthrea...wiring+correct
Old Jan 30, 2008 | 05:14 PM
I would do that but I already got money tied up in this. Now with that said this unit has additional relays that are used for other functions that I'm not going to use. But I would perfer not to have to gut this plug and play unit and try to rewire it to use the third relay. I don't really care if I have all the functions of the fans like one slow, or 2 slow or both fast. I simply want them to kick on when they reach temp. Noise is not an issue with me. I have to pusher fans in this car that simply turn on full blast when I turn the ignition on. But I would perfer that they not come on until needed. But again I don't need the full functions of the 3 relay set up unless this setup as wired want work period.
Old Jan 30, 2008 | 07:38 PM
blackrose90's Avatar
I have mine wired with 2 relays just like shown in the diagram. They come on at 200 degrees and go off at 190. Have had no problems.
Jeff
Old Jan 30, 2008 | 08:45 PM
Thanks Jeff, nice ride by the way, dig the color selection!
