engine ID question
Old Feb 4, 2008 | 01:02 PM
50adrod's Avatar
Default engine ID question
how can you tell a 5.3 vortec from a 4.8 if they are out of the truck already?
Old Feb 4, 2008 | 01:36 PM
72Elkytpi's Avatar
I had the same issue.
They both have the same block, just different diameter pistons. I checked the numbers on the back, passenger side of the block. Also there will be a laser etch number on the side of the aluminum head. I should match up with the VIN number.
Good luck
