What fuel pump to use?
Old Feb 10, 2008 | 09:26 PM
ryanvv355's Avatar
Anyone have luck with a Bosch 044?
Old Feb 11, 2008 | 08:27 AM
Schwanke Engines's Avatar
LS1TECH Sponsor
We have used them before, but, dollar for dollar, the Walbro wins hands down.
Old Feb 11, 2008 | 08:53 AM
ryanvv355's Avatar
What kind of power level is the Walbro good for, I've heard alot of people say they are not good for much more than 500hp. The Bosch a better choice for an FI application, to leave room for expandability?
Old Feb 13, 2008 | 08:12 PM
bada's Avatar
Are the external inline pumps OK. I have a fuel cell now, and hate to think I need to change tanks. Just to put a in tank pump system on it.
Old Feb 13, 2008 | 08:14 PM
Grewe02's Avatar
In the end setup, I'm going to be using something along the lines of this:
Old Feb 17, 2008 | 07:41 PM
jomomma's Avatar
my external mount pump is pretty noisy. the in-tank ones will probably be much quieter.
Old Feb 17, 2008 | 08:28 PM
bada's Avatar
what brand are you using, Does it work OK?
Old Feb 22, 2008 | 10:08 PM
65SSZO6's Avatar
Does Summit or Jegs carry to Walbro 255? and how much normal asperated HP is it good for?
Old Feb 23, 2008 | 10:52 AM
LS1TECH Sponsor
We have them in stock. They are good for around 700HP, NA
Old Feb 23, 2008 | 08:07 PM
jomomma's Avatar
ive got the a1000. it works great, but definetly noisy.
Old Feb 23, 2008 | 08:22 PM
boodlefoof's Avatar
On paper the Mallory 5110-FI pump looks to have the right specs for an LSx. Price isn't too bad either. It is an in-line pump and uses 8-AN inlet and outlet fittings.
Old Feb 25, 2008 | 03:52 PM
  #32
TomH's Avatar
FWIW, that's a Bosch 044 pump.
Old Mar 1, 2008 | 10:01 PM
  #33
Grewe02's Avatar
Tom, in addition to that picture, I would also need a return line from the motor, correct?
Old Mar 2, 2008 | 01:56 AM
  #34
TomH's Avatar
The trick is whether you have the "returnless" fuel rail. (The purpose of the regulator is to buffer the constant output of the pump against the variable demand of the injectors; the excess is returned to the tank. GM pioneered relocating the regulator from the rail back to the tank ~'98, and the '04 model year marks the point where virtually all Gen-III engines were converted to the return-less system)
The advantage of the returnless fuel rail (using the set-up in the pix) is that you're only running one line the length of the car. If you have the "right" rails, the return out of the filter/regulator is all you need. If you have the older return type rails, you can still use the filter/regulator and simply block off the return at the rail.
PS...
In-tank setups are perfect for the returnless architecture.
Good luck!
Old Mar 2, 2008 | 09:28 PM
  #35
steveelco's Avatar
are you guys using the in tank pumps or on the frame rail
Old Mar 2, 2008 | 09:46 PM
  #36
Sabre002's Avatar
Bosch 044 pump
look up Jay racing to get it and all the fittings.
old and busted fuel setup. Walbro 255 pump.
Then the new Bosch 044 pump
Old Mar 2, 2008 | 10:34 PM
  #37
TomH's Avatar
My set-up is the external in-line Bosch 044 in the pictures above. If I had to do it over again, I'd go with the in-tank pump. (Quieter and easier to plumb and FWIW, both Walbro and Bosch pumps can work in-tank.)
Old May 5, 2008 | 09:36 AM
  #38
MIGHTYMOUSE's Avatar
i guess i need to get that filter adapter to put this bosch in my tank.
i installed one without that brass piece on the end and it would not hold pressure, i guess that is the check ball assembly.. it looked restrictive... any info?
Old May 5, 2008 | 10:10 AM
  #39
johndeerrm's Avatar
Are the Walbro 255's loud?
I have the vortech t-rex pump and i can hear it over my dumped exhaust...
Old May 5, 2008 | 10:23 AM
  #40
RoDan's Avatar
nope, quiet as stock almost
