My LS1 Miata build
http://videos.streetfire.net/video/N...ack_207341.htm
I do not know the root cause of the failure, it could be that the boot busted and the joint dried up or it could be that the cage or bearings couldn't handle the abuse. I will take it apart and try to determine the failure mode. Dan at Racing Concepts is willing to help me out to get it replaced. More to come....
The new problem is that the outboard (miata) CV joint itself is toast. It could be due to a busted boot that then led to overheating and failure of the joint but I won't have time to take it apart for a while with school about to start back up. It is a stock miata CV that has been modified to accept the bigger shaft. I don't know how it was modified or any of that, I am trying to figure all that stuff out.
Its ford inboard CV and miata outboard ones with a custom shaft. I would think the miata cv is the weakest link in the axle. The shaft does not show any signs of distortion.
LS1-450, what is your rear end setup?
Mine's Ford 8.8 from the pumpkin to the hub (both CV joints). Your hub splines will need to be modified to go this route.
Basically 1.2g's steady state cornering on 225/45/15 Toyo RA-1's on a mid-40's degree day.
I did get the CV issue fixed, it appear the root cause was the boot busting which then dried out and destroyed the CV joint itself. So it does not appear the miata cv failed due to too much torque.
http://videos.streetfire.net/video/N...oss_638939.htm
There is a lot of wind/rattle noise from the camera unfortunately.
