LS1 swap wont start up
Old Feb 22, 2008 | 10:49 PM
95GreenZ28's Avatar
I am not sure if I did. Where is the theft deterrant module?
Old Feb 22, 2008 | 10:53 PM
jay_lt4's Avatar
the theft deterrent module is behind the dash, just to the right of the radio, attached to the airbag bracket
if you didnt connect this wire to your pcm the engine will crank but you will not have injector pulse
Old Feb 22, 2008 | 10:55 PM
95GreenZ28's Avatar
Ok I will try that tomorrow. Thanks so much for your help. I will post up here and let ya know if that was it
Old Feb 22, 2008 | 10:58 PM
jay_lt4's Avatar
it has an 8 wire connector on it:
a1 orange power
a2 pink power
a3 blue ***** (FUEL ENABLE SIGNAL)*******
A4 yellow theft relay
a5 gray security lamp
b5 black ground
b7 purple ign key resistor
b8 white ign key resistor
again wire a3 on the theft module needs to go to the red c2 connector pin 30 on the pcm
Old Feb 22, 2008 | 10:59 PM
95GreenZ28's Avatar
Alright. Thanks alot man! Helped me out big time. Would that make the injectors not even spray?
Old Feb 22, 2008 | 11:01 PM
95GreenZ28's Avatar
I pulled the plug out and it was completely dry
Old Feb 22, 2008 | 11:04 PM
jay_lt4's Avatar
yes, you will have fuel pressure but no pulse to the injectors without this wire
95GreenZ28's Avatar
ok excellent. Thanks again man!! I will let ya know
Old Feb 24, 2008 | 11:54 AM
95GreenZ28's Avatar
That wire is connected correctly and it still wont start up. No fuel past the injectors
Old Feb 24, 2008 | 04:06 PM
jay_lt4's Avatar
do you have injector pules while cranking(you need a noid light to check this, autozone or advance auto should have a set), also do you have power at the pink injector wires when the key is in run and crank position
Old Feb 24, 2008 | 04:11 PM
95GreenZ28's Avatar
I do have power to the pink wires but only if I ground it to the chassis. If I ground it to the injector I get nothing and i have no pulse at all
Old Feb 24, 2008 | 07:23 PM
  #32
Old Geezer's Avatar
Question U won't...
The inj shell is not grounded. Are you are referring to the other pin in the inj plug??
Power to 1 side of the inj and the other to engine ground should turn the inj on. Watch the fp ga, and see if the psi drops when you do this.
If the inj fires, then the problem is with the control of the neg side of injs. IE: the ECM is not pulsing the injs.
Old Feb 24, 2008 | 08:46 PM
  #33
95GreenZ28's Avatar
Correct. It isnt pulsing because the Vats has issues. I am sending my pcm to Jay to have it taken care of
Old Feb 25, 2008 | 01:02 PM
  #34
andrew69_04's Avatar
Vats will allow the motor to start. It will run for 3-5 seconds and will die, but it will start.
Old Feb 25, 2008 | 01:04 PM
  #35
95GreenZ28's Avatar
Hmm so that isnt the problem then. I have no idea what it can be. I get spark, fuel to rails, i have cleaned injectors, just no ground on the injector wires for some reason
Old Feb 25, 2008 | 01:58 PM
  #36
orangefun's Avatar
i would tend to think a bad ground might cause this, i could be wrong but i believe the injectors have constant power(+) while the key is on the the pcm grounds the connection to make the injector fire...just an idea
Old Feb 25, 2008 | 02:47 PM
  #37
I would check your harness over for a missed or bad ground. I would guess thats your problem.
Old Feb 25, 2008 | 03:04 PM
  #38
95GreenZ28's Avatar
I have checked it 3 times and I made sure all grounds have been connected. Im not sure what to do here
Old Mar 7, 2008 | 04:10 PM
  #39
wajouba's Avatar
what was the problem here did u find out yet? always come back and post so we all benefit...
Thanks
Old Mar 7, 2008 | 10:54 PM
  #40
just for your info. my swap i just finished up on. with vats in the computer and that theft deterent wire unhooked the motor would start. would run for 3-5sec and die. i had my vats deleted out and walla...it runs! Make sure all your pink wires have power with the key in the run and crank positions. Make sure orange have power at all times. the motor grounds are on the back of the driver side head. Also, do you have a ground from your motor to your frame? have you made sure you have 58-60psi fuel pressure. i have had motors with 30-40psi not even try to start. check that. If you have ignition, and proper fuel pressure, that leaves injectors to fire to make it run. Give us an update as to where you are.
