5.3 wiring harness Wiring diagrams here!!!
Old Nov 30, 2016 | 02:19 PM
radasch's Avatar
Default 2005 silverado pinout
Does anyone have a pinout for a 2005 L33 from a silverado HO?
Thank you
Old Oct 13, 2017 | 12:07 AM
1951chevy5window's Avatar
would this diagram work for a 02-04 5.3 lm7
Old Oct 13, 2017 | 01:55 AM
ls1nova71's Avatar
It says they're from an '05, so they would be real close to a 2003-6, the 2002 would be similar, but not the same due to the switch to DBW across the board on trucks in '03.
Old Dec 28, 2017 | 05:10 PM
untionic's Avatar
Can anyone locate the first Page of Fuse block under hood C1 that is posted above. There are three pages when 4 are needed. It is missing the A and the first of B. I am trying to do an LS swap and want to use this fuse block without reinventing the wheel. Snip and splice where I can to make things work.
Thank you in advance.
Old Dec 11, 2018 | 10:31 AM
snydmax's Avatar
I am desperately seeking a pinout for the bcm connectors on my 2007 yukon xl... has the 5.3l... thanks if anybody can help!
Old Mar 28, 2019 | 10:44 AM
dmo4sho's Avatar
I'm finishing a Swap of a 5.3 out of a 2007 Silverado into a cobra kit car. The harness is aftermarket from bp Automotive but the last few wiring labels came off. I'm hoping these are close enough to get it done.
Old Sep 26, 2019 | 05:06 PM
Abel Frausto's Avatar
any one have the same diagram but for a 2005 z71 suburban
Old May 21, 2020 | 03:22 PM
BBC 05 Silverado's Avatar
Can you send "Fuse Block - Underhood - C1" Gray!! A1 through B11. You are the only one online that matches my pin outs and you left off page 1.
Thank you for any help.
Old Mar 28, 2021 | 06:03 AM
Peter731208's Avatar
Default Pinout
Hi every body im looking for the pinout on a k4m engine np 200 nissan motor
Old Mar 28, 2021 | 11:08 AM
Why are you asking about Nissan wiring on a strictly GM forum?? Go to a Nissan forum if you REALLY want help. Otherwise you are a troll.
Old Aug 20, 2021 | 12:02 AM
NICK0310's Avatar
Default Ls harness
when transferring a bit of a harness from. A pcm that is color coded with red and blue plugs (donor) to harness and pcm with blue green green are pin out number the same?
For instance I have a drive by wire ls stand alone harness and I want to add the 4l60e harness to that configuration. And allow the factory pcm to be programed.
Old Aug 24, 2021 | 11:01 AM
  #32
duffyjon07's Avatar
Default pdf
Is there any way anyone can send me this wiring harness info in a pdf file so I can open it while working on the harness, I don't have internet in the shop, I'd like to be able to save as a pdf, or print it out. Also I've put a 5.3 out of a 2003 suburban in a toyota build and believe this diagram will work for me, if anyone knows better any other suggestions? I'd like to be able to use original gauges, and probably have to add a few. Running the 5.3 with a turbo 400 and an np205 transfer case in a 94 toyota extra cab pickup.
Old Aug 25, 2021 | 03:01 AM
  #33
xcomunic8d's Avatar
check lt1swap.com. I’ve found everything there. PDF and all kinds of useful stuff.
Ps im not affiliated…etc…
Old May 27, 2023 | 05:58 PM
  #34
gonejesus's Avatar
Originally Posted by axelfoxx
i need the 2001 schematic for a silverado 1500 :C all the ones i have found so far come nowhere close to matching my c1 layout
did u find one need it also
Old May 27, 2023 | 07:32 PM
  #35
He hasn't been here for over 8 years. Check post dates....
Old Jun 3, 2023 | 06:58 PM
  #36
jgordy's Avatar
Can you offer any assistance? I just acquired 5.3 out of a 2003 Suburban-drive by wire. I'm installing into a 71 c10. The harness is all there. Just need to label and identify all the gadgets, modules, sensors, switches, etc. Thx! Jay
Old Jun 3, 2023 | 07:09 PM
  #37
Aaaand, he hasn't been here for 2 years....
Old Jun 3, 2023 | 07:30 PM
  #38
jgordy's Avatar
Thx! Also, found a link that will help.
Old Jun 6, 2023 | 09:18 PM
  #39
underoil's Avatar
Can anyone confirm If I’m missing some pins, more on the red side of the connector. 2001 Chevy Silverado 1500 2WHD 5.3 LS. I ran OBD 2 and I have about 40 codes all related to the harness. Camshaft, 4WHD, Knock sensors, all four H02S and a misfire. They all appear right after I delete codes. Original owner since dealer back in ‘04 first time running scan tool. Other than that she runs we’ll never noticed a difference lately.
Old Jul 11, 2023 | 03:03 PM
  #40
ptaylo5784's Avatar
Default Your a true blessing!!!
Thank you very much been searching 2 wks now!! Finally I can track down my ground wiring problem!
