5.3 with a manual trans?
Old Apr 12, 2008 | 11:29 PM
dfe1's Avatar
Originally Posted by Quest-LM7
If a LS1 flywheel bolts to a 5.3 then all is good other wise maybe use a NV3500 flywheel and T5 clutch with a T5 trans. The sucky part is I wanna use a aluminum flywheel to get a little more horse and throttle response. Its to bad nobody has done much for 5.3 manuals.
Corvette Fever magazine is doing a project and is using a 5.3 in a 1987 Corvette. If I remember correctly, they used an LS1 aluminum flywheel and it bolted to the 5.3 crank with no problems. I believe GM offers a pilot bearing that installs in the outer bore of the crankshaft so if you use an old style small block/big block bellhousing, just about any type of transmission that was originally used behind a Gen1 or Gen2 engine will work. That includes Muncie, T10, T5 or T56 among others.
Old May 14, 2008 | 10:14 AM
jeepinpete's Avatar
Mark, I used a GTO flywheel.
