Front Coil Spring Question.
Old Feb 24, 2008 | 11:32 AM
Brer Rabbit's Avatar
Default Front Coil Spring Question.
I would like to keep at most a factory ride height on my GTO. The springs in the car now were too strong for the Aluminum headed Pontiac that I had in there before so I kjow it will be way too high for the LS1. Im thinking a 6 cylinder Chevelle spring might be good unless someone has a better idea? I would rather replace then cut.
Old Feb 25, 2008 | 03:59 PM
slygy0's Avatar
this is a great question, i have as ls6 in my 70 442 oldsmobile and the ls6 is a lot lighter than the factory iron that was in it. right now full weight the car is about 1.5 inches higher in the front. i was wondering what some other guys did with this issue. I think im just going to go 2 inch lowering spindles but let me know what has worked in the past.
