64 chevelle 5.3
Old Feb 25, 2008 | 10:27 PM
markarleta1's Avatar
Default 64 chevelle 5.3
whats up every body? i'm puting a 5.3/4l60e in my chevelle and need to know where i could get mounts. any and all info appreciated
Old Feb 25, 2008 | 10:48 PM
bczee's Avatar
There are many vendors and manufactors of the both just the adapter plates and complete kits.
Do some research in this forum and search out the A-Body swaps... Research the FAQ at the top of this section. There are to basic type of mounts S&P and BRP.. there are other manufactor of the S&P ... Hooker, Edelbrock, ATS, etc.. along with a 1" set back of the S&P style.
Figure out and plan on what front accessories you want to use as well as if you going to use AC or not.
BRP just release a new kit, you might want to look at that.. S&P has a complete line of swap parts and front drive accessories.
After you have research some. Please ask on specific questions and we will all be able to answer your question...
Search out Stealth71, he has a very good thread going on his swap of his Chevelle.. you can find my swap in a link in my sig..
Good luck ...
Old Feb 26, 2008 | 09:18 AM
Carshopinc.com's Avatar
LS1TECH Sponsor
I have several sets of conversion mounts in stock at this time, We used the standard mounts in our conversion and modified the crossmember for oil pan clearance.
Old Feb 26, 2008 | 10:35 PM
thanks! for the info
Old Feb 27, 2008 | 02:16 PM
65SSZO6's Avatar
Just got my 6.0L back from the machine shop.I am using Doug's Long tube coated headers and their motor mount plates,using a Street and Performance oil pan,pick up tube.I figure for $70 I would use Doug's adapters,so if I have any problems with engine/header fitment,no one can point fingers at one another.
Check out this S&P link http://www.hotrodlane.cc/Streetstori...velle.pdf.This may give you some idea of what you are getting into.
Old Feb 28, 2008 | 12:20 AM
thanks what do you have in your 65 any pics?
Old Feb 28, 2008 | 08:46 AM
Rameaux's Avatar
Can't wait to see this finished, I love new power in older cars.
