One Last harness question
Old Feb 28, 2008 | 09:19 AM
91parkave's Avatar
Moderator
Default One Last harness question
Ok i have one question , I have the neccecary diagrams, What im trying to figure out....before i convert the harness, because i have the Factory fuse block attached to the PCM and all connections when the engine got pulled, is how can i utilize it? where would i hook up my ignition wires? Thanks for any help, its from a 5.3 truck...
Old Feb 28, 2008 | 10:03 AM
ls1nova71's Avatar
I would say you would just have to trace the wires back from a circut that you have a diagram for, for example the injector 1 and 2 circuts are powered by the Ign 1 relay, so your ignition power from the ignition switch would power up the 85 or 86 terminal on the ign 1 relay. Does that make sense? I know what I'm trying to say, but I don't know if I'm saying it right. But anyway, that fuse box is huge, and you probably don't need as many circuts as it has anyway. Might be easier to just use something smaller. Hope this helps, good luck.
Old Feb 28, 2008 | 08:07 PM
G-Body's Avatar
sawzall wielding director
You have to connect your ignition to the body side of the fuse block, it should make it a lot less wires to connect. Let me dig through the diagrams you posted and I should be able to come up with more info....it just might take a bit, the dial-up internet doesn`t download very fast.
Old Feb 28, 2008 | 08:53 PM
G-Body's Avatar
I dug through until I realized that you were working on a 2001 5.3L, thankfully this has already been written up https://ls1tech.com/forums/showthrea...t=truck+wiring The information for how to wire the motor using the truck fuse block starts in post 13
