Conversion clutch master cylinder question
Old Feb 28, 2008 | 10:36 AM
cooks 7's Avatar
Default Conversion clutch master cylinder question
I was working on my clutch hydraulics last night and have a question. I adapted the stock 2001 clutch master cylinder to work with my stock triumph pedals but was wondering whether or not to put a pedal stop on the clutch. Is it bad to bottom out the master cylinder? If so, should I put a pedal stop to just shy of bottoming the cylinder out? I want to make sure I am moving as much fluid as possible but don't want to damage the cylinder either.
Thanks
Jon
Old Feb 28, 2008 | 11:35 AM
67rsss's Avatar
We made our master work with a turnbuckle and made a stop for it as well. I seem to recall that you should have 15/16" of travel.
Old Feb 28, 2008 | 12:40 PM
cooks 7's Avatar
Sounds about right, i was doing some quick and dirty measurements and it looked right at an inch of travel. So i should stop the pedal just short of bottoming out i guess. Anybody else have experience with the same situation, how did you solve the problem?
