Ls1 Front accessory brackets
Old Mar 3, 2008 | 12:34 PM
TransAm Mania's Avatar
Default Ls1 Front accessory brackets
I have an Lq9 going into my 79 T/A. I want to use fbody accessory brackets to avoid any fab work. I don't plan on running A/C so thats not an issue. Besides the alternator bracket, power steering bracket, water pump, and crank pulley, what else do I need as far as idler and tensioner pulleys go? Can I still use the alternator and Ps pump I have from the truck motor?
Old Mar 3, 2008 | 06:15 PM
SheldonZ28's Avatar
I just did an F-body Acc conversion on my LM7.
The only truck part that is compatible with the f-body accessories is the alternator. PS pump, waterpump, brackets, idler pulleys, tensioner etc are all different.
Old Mar 4, 2008 | 07:37 PM
Thanks
