need a lil advice?! PLS HELP!!!
pls help!!!!!!!!!
p.s. also wantin to do this on a tight budget, let me know!
I am not the expert on the older trany swap.. but other will ping in on this.. they will be able to give you the correct parts.. just wanted to chim in on the Trany question and tell you it can be done.
We carry a array of mounts for your conversion
Standard ls1 adapter plates to install the engine is the stock location:
http://carshop.carshopinc.com/produc...id/86959/LS1GM
1 Inch setback mounts (I suggest these for your conversion)
http://carshop.carshopinc.com/produc...457/C/S%202370
If you want to do a carb setup This is the intake you will need, This can get pretty expensive by the time you buy this and the carb for the conversion:
http://edelbrock.carshopinc.com/prod..._id/76819/2908
If You have any questions or need any help feel free to give us a call anytime.
Thanks
Elec
Carshopinc.com
I have a 5.3/T56 combo in a 1992 fullsize truck, and love it.
I bought a shifter relocater kit from keislerauto in Knoxville so I could use the shift hole in the floor.
You will also have to move the crossmember and shorten the driveshaft if you go with a T56.
You might also go with one of the tremec tko.
I don't know if this will fit the budget or not, but it is an option, and fwiw you end up spending a lot on the little things with a T56.
I found that out, but am still glad I have it as it is a blast to drive.
