Any msd pro data+ users around?
out of interest shawn, what fuel pressure does your carb run? i've been told my demon will need around 7psi constant, which is what its set to now. the reg was playing up before tho, sometimes at 5psi sometimes more, and the float bowl ran out of fuel then at WOT, mainly foam bubbles in the sight glass. :-(
hoping i cured that tho now!
http://www.carcraft.com/techarticles...comp_cams.html
