What rad hoses for a 69 camaro?
I'm probably going to go with a set of those metal flex hoses--they come with adapters to neck down to a variety of sizes. Spectre and a couple of others vendor make them.
http://store.summitracing.com/partde...5&autoview=sku
for the lower i just forced a 1.5 inch hose on the 1.75 inch radiator outlet.
works fine.
jegs and summit have an adapter that is 1 1/2 x 1 1/4, and a petcock-you could use that maybe for the top, and unscrew the petcock and use that for the bypass hose maybe-the s10 trucks had some smaller hoses-you might get away with an upper hose for a 2000 5.7 camero, and your old hose to the radiator and the adapter
the bottom hose is 1 3/4, i think a truck thermostat housing is at least 1 1/2",
and one of those rubber bushings (reducers) and you might get away with a stock lower hose-even some stock upper hoses might work with the bushings
i usuall go to the auto store with a bent wire and meas tape, they let me roam thru them
