MSD 6010 users
Old Jun 18, 2008 | 08:12 AM
SMAX's Avatar
Got it to work last night. With the #1 pill the car would start with no throttle and had amazing throttle response. Well I plotted a timing curve and it started at 0*@0rpm went ot 17*@1000rpm and then 28* from 3k up. Well with that I had to give it gas to start it and it would sputter when I revved it until it got above 1000rpm's and then it would clean up.
I then jumped timing at 100rpm's to 17* and now it is back to no throttle start and a nice responsive clean rev. What kind of timing curves are you guys running?
I haven't yet started on the carb, but I honestly don't think it is going to need much tuning.
Old Jun 18, 2008 | 08:56 AM
dman's Avatar
i plugged in pill 1 as well. i'm going to copy the idle/part throttle curve from that and create my own for WOT
Old Jun 18, 2008 | 10:50 AM
chris-m's Avatar
yea dont forget to remove the pill or it will overide the curve you plot.
Old Jun 18, 2008 | 10:53 AM
SMAX's Avatar
Yeah, I just put the pills in the tool box.
Old Jun 18, 2008 | 12:43 PM
dman's Avatar
yeah good point. the pill must not be in when the key is turned on. pulling it out after you've powered it up does nothing
Old Jun 19, 2008 | 12:16 PM
Sheephead's Avatar
Where are you guys installing your map sensor?
Old Jun 19, 2008 | 12:32 PM
dman's Avatar
i just used the factory MAP sensor for now. But I also have an older style 2 bar that i will need to change the harness plug to get working. any vacuum source will do.
Old Jun 19, 2008 | 06:07 PM
Pop N Wood's Avatar
Ported or unported
Old Jun 19, 2008 | 10:40 PM
cowfarmer's Avatar
unported - you want full manifold vacuum
Old Jun 20, 2008 | 08:16 AM
bluethunder364's Avatar
Can you run without the map sensor? Would it work better with it??
Old Jun 20, 2008 | 08:50 AM
chris-m's Avatar
you can run with or without it. i've used it to add some advance which cleans up the exhaust at idle and part throttle. once you get wot the map reverts back to fixed max timing of about 29-30 deg which suited our UK fuel on the dyno.
Old Jun 20, 2008 | 09:14 AM
  #32
Sheephead's Avatar
Thanks thats what i was looking for
Old Jun 21, 2008 | 06:32 AM
  #33
DCx's Avatar
DCx
SMAX, here is a copy of my curve. i had a someone plot my graph for me so i cant explain the dip in the curve. i think im going to remove it.
anyway same concept 17* from 0-1000 and then a slow ramp to 29* at 3000
http://i127.photobucket.com/albums/p...dls1timing.jpg
no issues at all. i can rev the hell out of the car. it starts, idles, and shuts off with no hassle.
Old Jun 21, 2008 | 09:58 AM
  #34
Sheephead's Avatar
Whats your motor Combination?
Old Jun 21, 2008 | 05:27 PM
  #35
DCx's Avatar
DCx
Stock 2001 LS1 short block
Texas Speed Stage 1 ported LS6 heads
Edelbrock Victor Jr intake
MSD 6LS timing box
Texas Speed Magic Stick 3 cam - 237/242 .603/.609
RollMaster double roller timing set
Stock Rockers
Texas Speed push rods
LS7 lifters
Wegner motorsports valley tray with breather
Melling high volume oil pump
ASP 25% underdrive pulley
ARP head bolts
ARP rod bolts
ARP balancer bolt
ARP rear cover bolts
autokraft oil pan and pickup
Hooker 1 3/4 ceramic swap headers
Carshop engine plates
energy motor mounts
Fbody accessories
750 Mighty Demon carb
Old Jun 21, 2008 | 11:49 PM
  #36
Sheephead's Avatar
"Wegner motorsports valley tray with breather"
Is this a needed part with the carb. setup?Are engine combinations are close ,i,ll be using your timing table as a place to start. Thanks
Old Jun 22, 2008 | 12:12 AM
  #37
DCx's Avatar
DCx
i just used it as a breather. i think its a really tick piece since my valley tray doesnt have the ugly knock sensor holes in it. i have a PCV valve in my drivers side valve cover that goes to the back of the carb. no need for power brakes, im running a hydroboost.
Old Jun 22, 2008 | 07:12 AM
  #38
forcd ind's Avatar
dcx-where you have your breather, i was thinking of putting one-Jegs sells an adapter(quick fuel, i think) that has an o ring and large nut, then you install the breather in it-no welding, just cut a hole
i used them on v/c's before, pretty cool
Old Jun 23, 2008 | 10:01 AM
  #39
holley505's Avatar
Nice setup on the ELKY
wieght of vehicle?
what stall you running? 4000?
what are you times? 1/4? (sorry, I may have missed that in the post)
Old Jun 23, 2008 | 10:31 AM
  #40
SMAX's Avatar
It weighs around 3100-3200lbs with me in it. The stall is a continental 4k nitrous stall. I haven't made it to the track yet, but I am hoping to get it close to 10's N/A and then put the nitrous to it. I know it feels really strong.
