Torque converter switch?
Old Mar 29, 2008 | 02:59 PM
wave1957's Avatar
Default Torque converter switch?
On my harness, I have a pink and a purple wire (for torque converter control) that I am supposed to connect to the brake switch of my car. These wires are supposed to get 0 volts when the brakes are applied, but my brake switch works "the other way": 1 wire is always hot, the other wire is hot when the brakes are applied...
How do I solve that?
Old Mar 29, 2008 | 03:39 PM
ls1nova71's Avatar
Depends on what kind of brake switch you have. If you have the old style GM brake switch you can get one for a car with cruise control, they have two switches in one, one is normally closed and the other is normally open. When you hit the brakes they do the opposite. Then wire your torq converter to the normally closed side of the switch on one terminal and ignition power to the other terminal.
Old Mar 29, 2008 | 10:50 PM
lsxyj's Avatar
u can do it with a relay also
