Progress report
Old Jul 27, 2003 | 11:20 PM
Project GatTagO's Avatar
Default Progress report
Hi Guys,
Here are a few pictures. I been busy!
Andrew
Old Jul 28, 2003 | 12:16 AM
John B's Avatar
Moderator
Default Re: Progress report
Lookin good!
Old Jul 28, 2003 | 11:06 PM
Derek 357i's Avatar
Andrew, looks great, can't wait to go for a spin. What did you ever find out about your engine?
Old Jul 29, 2003 | 12:02 AM
I basically found out that it was most likely a late, preproduction test mule, most likely used to emissions testing. The heads were a bit odd. They have the LS6 exhaust ports, but they had standard LS1 valves. The springs looked to be standard LS1 items as well. The bottom end checked out fine, and I think extra care went into putting it together. All the connecting rods were numbered with the respective cylinder numbers. That tells me that it was blueprinted.
In the end a Comp cam was installed and the springs swapped out to a set of 918s. I added the Holley intake mainly because I had it, and secondly because I did not want to use the manifold that came on it. Should be good for about 350 RWHP, maybe a bit more.
Andrew
