correct connector for t56 vss connector??
Old Apr 4, 2008 | 09:22 AM
SPG's Avatar
SPG
Default correct connector for t56 vss connector??
is this the right part??
Connector Part Information
1216-2195
2 Way F Metri-Pack 150.2 Series Pull to Seat (BLK)
Pin
Wire Color
Circuit No.
Function
A
PPL
401
Vehicle Speed Sensor (VSS) Signal - Low
B
YEL
400
Vehicle Speed Sensor (VSS) Signal - High
Old Apr 4, 2008 | 04:00 PM
JMitch19's Avatar
It's either that one or 12052646. We are now building a harness that has all three t56 connections. We are building this harness for ATS who is a sponser here. Tyler can probably tell you more than I can. The harness has the back up lights connector, reverse lock out connector, and the VSS connector. The back up light and Reverse lock out connector look similar and I'm not sure which is which. I'll try to find the harness build instructions so I can be a little more helpfull. We just shipped the first batch of these to ATS yesterday so I'm not as familar with this harness as some of our other products.
Old Apr 4, 2008 | 08:10 PM
LS1MCSS's Avatar
If you look at the link below you will see two different connectors for the VSS. The small one will fit the 4l60e and T56. The large one is usually found on some trucks that had a vss in the transfer case.
http://www.speedscenewiring.com/v-we...e66da0e1b03df0
