where to mount inline fuelpump on 69 camaro
Old Apr 9, 2008 | 07:03 PM
JAY ROD's Avatar
Default where to mount inline fuelpump on 69 camaro
where are you guys mounting your inline fuel pumps?My pump is a walbro 255.My car is a 69 camaro.
thanx
Old Apr 10, 2008 | 10:53 PM
jtune's Avatar
i dont have a camaro but did use the inline walbro. I mounted it as close as i could to the tank. I have maybe 18 inches of fuel line between the tank and pump.
Old Apr 11, 2008 | 07:43 AM
rockytopper's Avatar
I mounted a rail across in front of the tank to mount the fuel pump and regulator filter as close to the tank as possible. you can see it in my project thread.
https://ls1tech.com/forums/showthrea...762&highlight=
Old Apr 11, 2008 | 11:49 AM
andrew69_04's Avatar
i mounted mine on the inside of the frame rail above the driver side rear axle. the regulator is right there too.
Old Apr 12, 2008 | 12:32 AM
1442's Avatar
i have a 69 camaro ls1 6 speed drive by wire, i mounted in center backside of tank filter also. your going to have fun when your done , 2 tire worth trust me
