Steam Vent Hose Question
Will it harm anything if it is pluged? seems like a pretty usless hose.
You can get some tee's that will go to either the radiator or heater hoses. that would be the quickest.. may other Truck or cars have them and you might be able to find a applicaiton and use just the tee.
You can get some tee's that will go to either the radiator or heater hoses. that would be the quickest.. may other Truck or cars have them and you might be able to find a application and use just the tee.
No kidding - why borrow trouble? Even if you braze a little "nipple" onto the top of a radiator tank, or have to replace a section of your upper rad hose with a section of pipe with a fitting, it would really be best to keep the fittings/functionality that the factory designed in.Think of it this way - given the way that GM (heck, seems like all major corporations these days) would like to save a nickel on each unit, do you think they'd retain that stuff if it wasn't absolutely necessary???
