Thinking about an 86 Trans Am LS1 Swap
Is there a pain free wiring system for it? So I need not worry about all the gauges, fuel, spark and all that?
Are there headers out there, prefer long tubes so I can make it the same as my 99 Z28 exhaust.
How hard is this project? I have a welding buddy..so no worries...can someone give me a heads up of the headaches to expect?
Appreciate it guys...Bobby.
Then click on the 91 Z28 link. You'll find some info there.
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
I already checked out that site. I don't see any major problems, All I see is the motor mounts need to fabbed up (unless someone sells them out there) and the tranny mount needs some help. Other than that, seems fairly easy. Just hope I am not biting off more than I can chew.
www.speartech.com
Also, gauges...will I have a problem with Stock gauges? I want to keep them because the car is canadian (Metric System), and it is kinda rare in Texas.
More info here: www.speartech.com/customharnessinfo.html
When you remove the old engine, keep track of the oil pressure and water temp wires, and I can walk you thru an easy hookup of your gauges. The tach requires an adapter box ($80), and to maintain your mechanical speedo your best bet is to use the Abbott X-box. around $300 I think.
www.abbott-tach.com/cablex.htm
www.speartech.com
Thanks a ton. This is sounding easier and easier, just costing me more and more, hehe.
With the brackets buyable, and the harness buyable, sounds like cake. I know exactly what wires are the water temp and oil pressure as I had a 85 trans am i did a lot of stuff to a few years back, engine in and out like 4 times...
Thank you for all of your help and link, this might not be as bad as i thought it might be. I appreciate it.
Bobby
