Finally starting to come to a close
-Mount the battery box in the bed and run the wire
-Adapt the truck injector electronics to the car injectors
-Run the fuel lines (need the adapter parts, thats a question for you guys)
-Get the shifter working (old floor shifter for my old 4l60e needs to work with the 4l80e)
-Need to build a rad support
-Need a cap for the power steering resivoir
-gotta get the old 5 inch tach the origional owner added
-Need to get the new seats mounted (APC... i know i know...)
-check all the bolts
-Mount the fuse terminal on the engine harness to the firewall
-Needs a computer tune
-Needs new shocks (fronts and rear)
-Wire up the electric fans
-get some parts painted
- needs exhaust
ok so I have a few questions to ask:
1. suggestions on what pillar guages to get
2. Need suggestions on shocks, since I cant find 90 / 10's for the front???
3. I need to buy fuel line, wanna do braided, I have FAST fuel rails, I need a T and will sneak both lines up one to each rail, what fittings do I need to do this?
4. I need to build an intake, suggestions?
5. The shifter is almost impossible to move once we tighten down the bracket onto to tranny, ideas?
