5.3 Vacuum port required
ACDelco 12559760
"GM Original Equipment Power Brake Booster Vacuum Hose Connector"
$7.50 with free shipping on Amazon.com. Also not too expensive at the dealership..maybe ~$12 if I recall correctly.
http://www.novak-adapt.com/catalog/e...gine_parts.htm
I like the fact that it's a quick-connect kinda fitting so when I go to hydroboost I can just pull the nipple out and pop the factory plug back in with about 5 seconds of effort. Also, FYI to all, it is the same fitting on the 2000-ish intake I had on my LM7 and the 2010-ish intake that I put it into. Could have just swapped it over. Doh.
