edelbrock headers
Old May 7, 2008 | 03:09 PM
65SSZO6's Avatar
Summit has 0 of these headers in stock.I just checked with their wholesale side and they said 0 are in stock and they would drop ship.$500+ shipping is a steal! I can not even buy them for that much.I would check that who ever is doing the group purchase has them in stock ready to ship!
Old May 7, 2008 | 04:11 PM
430 hp 70's Avatar
well i have a guy thats selling them to me at the $500 price and im the one that started the gp. ill check with him to make sure they are in stock. if not, it wouldnt be any different than getting them from someone else. if edelbrock doesnt have them, nobody has them.
Old May 15, 2008 | 01:22 PM
Brer Rabbit's Avatar
Default Headers came in.
My buddy got his in a few days ago, I have to say they look like they were just painted with a dull gray paint. I read somewhere here they were stainless but they sure dont look like it. Anyway the passenger side header did not fit in when I tried to slide them up from under the car. All kinds of clearance issues. Considering that I dont have the motor leveled and completely bolted in yet they still might work. Just some observations.
Old May 15, 2008 | 04:14 PM
430 hp 70's Avatar
i put mine in my 70 last night and they worked perfect. where are yours hitting? 64-67 or 68-72? you may not have the motor back far enough. if you didnt spin your mounts or if you dont have the edelbrock plates they might not fit.
when i first dropped my motor in the stock location, i had about 5" from the head to the firewall. thats been taken care of.
the coating is kind of lame, but when was the last time you saw a painted looking header hold up to heat. i actually real like the coating. these are perfect for the non bling guys. ill see how they look with my finished product but i may have them coated again to make them shiny.
btw, the quality looks excellent. nice welds and heavy duty construction. and although the color looks like a paint color, i dont think they actually look that way.
Old May 15, 2008 | 04:42 PM
1970-Cloned's Avatar
I am going to run the headers also the way they are. If the coating does not hold up I will have the Jet hot or some other Ceramic coating.
I had no issues with header fitting in my 70 chevelle.
Old May 16, 2008 | 11:35 AM
EdelExh's Avatar
The paint we are using is a ceramic based coating and will actually get harder with time and heat, it will not dull or change colors. The Edelbrock Headers will not work with just any engine mounting plates, most of the others on the market move the engine way too far forward in the chassis, with the Edelbrock Engine Plates (6701) the engine sits in the correct location for superior weight distribution. Also with the engine in its correct location things like shifter linkage line up in the OEM brackets so column shifters can be retained, or if you desire to keep the current transmission in the vehicle then all the mounts and driveshaft will be the same.
Old May 19, 2008 | 01:49 PM
Default Ur mounts with L460E
Have U determined if there is enough clearance in the trans tunnel with a L460E when using ur mounts? Let me be more specific.... I need this to fit in a 67 GTO. It seems that maybe the Pontiacs are a lil tighter in the tunnel then the Chevelles. Ive already done some massaging but it looks like Im gonna have to do some welding?
