cooling fans
Old Apr 26, 2008 | 10:22 PM
ls1cutlass's Avatar
Default cooling fans
Hey guys about done with my swap but need to know if the cooling fans out of an f body are pullers or pushers dont know which direction they should run thanks for the help
Old Apr 26, 2008 | 10:34 PM
G-Body's Avatar
sawzall wielding director
The f-body fans are pullers
Old Apr 27, 2008 | 08:42 AM
Shawn MacAnanny's Avatar
Doesnt matter they run on DC, just switch the wires and you can make them pushers. I've done this on a couple other swaps. DC motors can run either way.
Old Apr 27, 2008 | 11:05 PM
G-Body's Avatar
Be careful if you try to reverse the direction, that only works on some of the fans. I tried to do that on a v6 f-body fan and it didn`t go well. When I powered it up in reverse it had a huge arc as I connected the wire, the blades had the wrong curve so it didn`t push much air, and the motor started to smoke....so I think there may have been a diode in there and I was creating a short across it by connecting it backwards.
So just be careful, before you go through the work of mounting the fan make sure it will work if you reverse the direction.
Old Apr 28, 2008 | 04:56 AM
Hmm i guess I've just been lucky then. Yeah always try before you waste your time doing haha.
