VSS Hook up
Id like to use the factory VSS module from the truck. Its a 2000 pulse per mile setup, 3 wire hookup. It gets a 12V IGN feed, chassis ground, then a signal to the PCM. The LT1 PCM is a two wire hookup with both wires going/coming from the PCM. I'm wondering if anyone has any suggestions of how to wire this up? I'm guessing the factory truck one just sends pulses to the computer. How does the later LT1 style do it?
How does the factory unit regulate pulses?
