Car dies
Old Apr 30, 2008 | 12:50 PM
zapp168's Avatar
Default Car dies
Hey guys....Putting a LS1 into a RX7. Still in mock up stage, but had to hear it run. The motor starts runs ten seconds or less and dies, have not done any diag yet I figured I would ask to see if it is a common problem that anyone has had. We have the fuel pump hard wired so it runs with the key in the ignition position. Thanks
Old Apr 30, 2008 | 01:17 PM
99NMB's Avatar
VATS. have you had the vehicle anti theft system tuned out of the computer?
Old Apr 30, 2008 | 02:33 PM
zapp168's Avatar
No, I thought that then I was not sure what effect it would have, I thought it either caused a no crank (it cranks), or it caused the fuel pump to shut off after it started....(thus the hard wired pump). I will search for Vats. thanks for the tip!!!
Old Apr 30, 2008 | 09:36 PM
G-Body's Avatar
sawzall wielding director
VATS kills the injectors not the fuel pump.
Old Aug 21, 2008 | 09:17 PM
zapp168's Avatar
Thought I would post up, Yup it was the VATS Thanks G-body I did not know that about the injectors....
