Trans bell housing bolt size?
Old May 4, 2008 | 08:48 AM
prrc's Avatar
Default Trans bell housing bolt size?
Any one know what size bolts are used for the trans bell housing on an LS2.
Thanks Tim
Old May 4, 2008 | 09:56 AM
Project GatTagO's Avatar
Thanks Tim
10 mm x 1.5 40mm long
Those would be the bolts for attaching the bellhousing to the block.
Andrew
Old May 4, 2008 | 10:26 AM
prrc's Avatar
Andrew, Thanks.
Old May 4, 2008 | 01:50 PM
Andrew, Thanks.
You are welcome. McMaster Carr has these bolts for a very reasonable cost. They are very similar to the OEM bolts with a reduced head and generous flange.
Andrew
Old May 4, 2008 | 06:22 PM
fmowry's Avatar
Andrew, do you know the part number on these? Is it: 91310A638? It's hard to tell which will have the smaller head, and I'm looking for the same part.
Thanks,
Frank
Old May 5, 2008 | 08:52 AM
Thanks,
Frank
Try this PN:
92820A550
For future reference, search for Flange Bolts, on the Mc Master site.
Andrew
Old May 5, 2008 | 04:50 PM
Shawn MacAnanny's Avatar
Go to a John Deere dealer. I got mine from them for like $.75 each or something. They are an excellent source of grade 10.9 metric bolts.
