Plate between T56 and bellhousing?
Old May 9, 2008 | 12:22 PM
blownmiata's Avatar
Question Plate between T56 and bellhousing?
This is probably a stupid question so I apologize in advance. I am trying to shoehorn an LS1 into a '99 Miata - I have my T56 bolted up to the bellhousing, and there is at least one spot where I can see the flywheel. Is there a plate or plates that I need to close these gaps? I know that the auto trans have flexplates, but what does the T56 need?
Old May 9, 2008 | 02:30 PM
Steve VanS's Avatar
A starter motor on the RH side, and a little plastic plate on the LH
Old May 9, 2008 | 02:41 PM
rao's Avatar
rao
There are little plastic covers on both sides.
#15 and #16
File Type: pdf
Old May 9, 2008 | 02:51 PM
blownmiata's Avatar
Great - that's exactly what I was looking for. Now, anyone know where to buy some of these plastic covers? I did not see them on gmpartsdirect, and I assume that parts stores won't have them....ebay?
Old May 9, 2008 | 02:57 PM
BlackSS2001's Avatar
Have you tried a local dealer? at least get a part # from them it there price is to high.
Old May 9, 2008 | 03:42 PM
rao's Avatar
rao
The Part Numbers are LH - 12558718, RH - 12561536
Old May 10, 2008 | 06:02 PM
blownmiata's Avatar
Thanks alot guys - I appreciate the help.
Old May 11, 2008 | 03:02 PM
Rodder's Avatar
Those plastic panels attach to the stock oil pan... anyone seen something that attaches to the bellhousing and works with an aftermarket pan?
Old May 11, 2008 | 08:30 PM
Project GatTagO's Avatar
Get some thin sheet metal and some tin snips. Make a cardboard template then cut the sheet metal out. Use the two bolts on the bottom of the bellhousing to hold it in place.
Andrew
