More Drive by Wire Questions
-The 2002 Escalade has a 9 wire connection between the pedal and TAC.
-The pedal assembly they sent me has the later (2006, 2007) 6 wire connection between the pedal and TAC module.
Can I use the later, 2006, pedal and TAC module with my 2002 Escalade computer?
Or do I need to find a 2002 9 wire pedal assembly?
Or could I buy the 2002 accelerator pedal position sensor and swap that out on my 2006 pedal assembly?
You need the 9 terminal pedal and the TAC module from an 01-02 truck.
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
BTW, Could you guys make me a a TAC module to pedal harness with hookups for cruise control?
Yes, we have the pedal to module harnesses for $50 each; whatever length you need. The cruise control wiring is not part of that harness though. It's in the other TAC module connector.
www.speartech.com
