HELP! Motor will crank but not fire!
Old May 19, 2008 | 07:45 AM
cjcrazy8's Avatar
Default HELP! Motor will crank but not fire!
Alright guys, here is the background. 98 LS1 from an auto Firebird TA. Now in a manual 83 jeep scrambler. Computer flashed to remove unnecessary items (AC,Emissions, Evap, VATS, etc.). Harness modified to remove those items as well. PCM IGN FEED ran to IGN power through a fuse. PCM Battery Feed ran to Constant Battery power through fuse. All Fuel Injectors and Electronic Ignition Contol Modules run to IGN Power through a fuse. Motor will crank but not fire. Not getting a steady spark. I have fuel and oil pressure. What am I missing?
Old May 19, 2008 | 11:29 AM
hpmotorsports's Avatar
Need to ck power to the injectors and coils while you are cranking, ck all power wires while cranking, alot of time they will have switched power and no power while cranking.
Old May 19, 2008 | 01:54 PM
JAY ROD's Avatar
make sure your cam sensor is grounded as well as the coil packs.
Old May 20, 2008 | 06:45 AM
cjcrazy8's Avatar
Default Thanks Guys
Thanks Guys. The PCM IGN FEED was not getting power during cranking. I jumped that wire straight to the battery, cranked it, and it fired right up. Now it runs for 2-3 seconds, so I guess I did not have the VATS removed. I guess I will build a bypass. That will be a nice extra security function.
Old May 20, 2008 | 07:25 AM
Glad to hear you got it going.
Old May 23, 2008 | 12:14 PM
cjcrazy8's Avatar
Default Vats Bypass
Alright, I made the bypass acording to the writeup on the corvette forum. I have 5v not sure about 50hz yet. I wired it up to pin 11 (theft deterrant) that runs to the body module. IT still only runs for 203 seconds. What did I miss? I have a 98 motor, would it be looking for a different signal? Any tips?
