168 tooth 5.3 flywheel part #
Old May 25, 2008 | 12:43 PM
scottiebobbie's Avatar
Default 168 tooth 5.3 flywheel part #
I have a 02 5.3 I am putting in front of NV3500 with this adapter
https://eshop.advanceadapters.com/co...591-712591.htm
my ? is does anyone know a gm application w/ a 168 tooth flywheel that will work or a napa or gm part # for a flywheel and clutch.
Old May 25, 2008 | 04:29 PM
Project GatTagO's Avatar
Why can't you use any LS1 168 tooth flywheel?
What is the size of the NV 3500 input shaft? Diameter and spline count?
Andrew
Old May 26, 2008 | 10:10 AM
input on the tranny is 10 spline 1 1/8" dia.
and to edit my first post the tranny is a Jeep NVG 3550 Transmission
Old May 26, 2008 | 10:12 AM
So use a stock LS1 flywheel and pressure plate. Have your favorite company make you a custom disk with a 1 1/8" x 10 spline disk.
Andrew
