Help me check my order list?
I have: headers, fuel regulator, throttle cable, BRP stylemounts, harness/ecm, o2 sensors, plugs, wires
my order list:
1) Fuel system:
Tanks Inc in tank sumped pump
(2) 3/8" RUS 639210 fuel fittings
(1) 5/8" RUS 640860 fuel fitting
*what do I use for a quick connect on the fuel rail?
2) Napa radiator hoses: 8244 and 7902
3) Power steering
Rus 632600
(3) Rus 620421 adapter fittings
Does this stuff look right? What else do I need?
I appreciate any ideas guys!
btw the quick connect 5/16" fitting is out of stock on summit, anyone know another good place to get one?
http://cgi.ebay.com/ebaymotors/TCC-B...spagenameZWD1V
and one of these or something similar if your doing your on harness from the factory harness
http://cgi.ebay.com/ebaymotors/LT1-L...spagenameZWDVW
and a pnp (park neutral position switch). I used a microswitch limit switch for this one and built a custom bracket to mount it on the trans next to the shifting fork. Apparently park is the most important postion it needs to read. Neutral is not required. It adjust idle based on it being in park or in gear.
what would you attach it to? I was under the impression only 1 connection was made to the 4l60e
http://cgi.ebay.com/MICRO-SWITCH-BZ-...2em118Q2el1247
I used the same switch for TCC because I did not find the one I linked above until I was done.
