Wiring harness questions
Put power to pink wires on the 3 C plugs, wired up the diagnostic port, put 12v constant to the orange wire in the C plug, removed all the wires from the pcm plugs as recommended in the sticky.
Also put a lead on the fuel pump relay wire.
I'm not doing A/C or electric fans so is there anything else I'm forgetting here?
This plug is cut off my harness so I need to order one, but a search for "cam angle sensor" turns up nothing on ebay, but cam position does
had "crank angle sensor" listed too so I was pretty sure they meant position sensor
