PCM Mounting Photos
Thanks,
Andy1
In my 68 Cutass (GM A Body) I used the plastic PCM holder from the 2002 TA donor car. I cut some off to get it as small as possible. I mounted this behind the gloove box. Screws up from end of plastic up thru cowell hold in place. Nuts would be visible when looking down thru cowell screen only with hood open. I had Speartech add enough wire to mount here. With stock harness I doubt this would work.
PCM is not easily visible and all wring is tucked up under the dash. PM me if you want pics.
For the PCM it is behind the firewall on top of the Trans tunnel with a small console hiding it with some idiot lights and gauges. I just used a 3/4" x 1/8" strap of metal and attached it to the PCM plastic mount, and then using the strap in a U shape to bolt to the trans tunnel. I cut off any plastic that was not needed.
Pat
