04 GTO Vats disabled
OR
If I had the original BCM will any of the traditional tricks work (ie can I trick it with 1/15 different resistors).
I need to purchase another license (different vehicle type) in order to program my PCM. Which... I am trying to avoid for the time being as money is tight.
Also can the Traction Control Module (the one beside the PIM module) and wiring be removed from the engine harness. From the schematics it doesn’t seem to have any control/communication with the PCM/BCM and looks like it can be pulled without any consequence. The same goes for the EBCM (electronic brake control module)?
