Drive-by-wire, drive-by-cable, combined
I mounted the actuator on the passenger inner fender, made a bolt-on bracket at the coil packs and extended the throttle cable with a small rod end and some rod threaded on each end.
I cut the wires from the cabin connector and extended the harness over to the actuator.
