HELP!!! LS1 69 chevelle swap
Check your fuel pressure to make sure your getting continued Pressure and it is not cutting off? How is the Oil Pressure ?
Check for Vacuum leaks ?
but 1st things 1st. VATS !?
but i will be at the shop on monday to have the guy go over the computer again if i am not able to get it to run tommorrow. thanks for the suggestions guys, this is turning into a nightmare.
