6.0 into 68 firebird
First, will the truck intake clear the stock hood or should I be looking for an f body intake?
Second, I saw the stock truck pan hangs way low, what stock pan should I use to clear the stock steering, or, am I forced to modify one or buy an aftermarket one?
Third, will the stock truck accesories clear the subframe/steering box/hood?
I think that's it for now but I'm sure I'll have more as I get into it
a oil pan specific for 67-69 camaros swap is available, so it should work in your car
might as well go with fbody, gto, or corvette accesories, the accesorie bracket for trucks is huge and bulky
Will the truck intake clear the hood though? I know ls6 is best but thinking pure budget at this point. For now will it work until I upgrade?
And do I need the swap pan or is there a stock one that will work?
the truck accesory is a large bracket that holds the ps pump and alt.
the truck intake is pretty tall, may not clear the stock hood.
also the truck accesories are spaced further away from the block, the corvette has them tucked in closer to the block. different offset crank pulleys
How's the camaro coming?Next question, planning on doing a turbo set up also. Most likely twins. Anybody use flipped truck manifolds in a first gen? Or, should I be looking into a set of CTS-V manifolds?
