Help with "Buck"
Old Jul 23, 2008 | 07:07 PM
NMCA Scott's Avatar
Default Help with "Buck"
As some of you know I have a '66 Buick Special project car we're building for Fastest Street Car Magazine with a (carb'd and stock) LS2 GMPP crate motor in it. The builder of the car wants to stick the alternator up high on the driver's side. The car has no air, and no power steering so we don't need something impressive.
He's old-school and is not LS savvy (and hell, I'm not either).
I know there are pulley kits out there but I don't need new pulleys at this point in the project. I have consulted Madman who turned me onto Larry at SpeedInc. They have what I need, but I already have a Powermaster alternator, so while using the kit from SpeedInc would be cool (which includes the alternator) it really doesn't make a lot of sense at this point.
The bottom line is we are having a hard time finding a bracket for this thing. Does anyone make a custom mount or should we just use a C5 bracket and be done with it? I have also heard that you can yank one off of a truck and use it.
Any help will be appreciated guys.
Scott
Old Jul 23, 2008 | 07:43 PM
Sheephead's Avatar
Default truck accessories
I would run the truck accessories you'll need the water pump, crank pulley, tension er, alternator. It would probably be cheaper to buy all these then buy aftermarket brackets. I did the same thing. Good luck
Old Jul 23, 2008 | 07:49 PM
NemeSS's Avatar
run the c5 bracket or the truck, the truck bracket is huge, also houses the ps pump,
or locate the alt. to the pass side using the stock fbody bracket , or the alt. relocation brackets used on fbodies for truck manifold turbo builds.
plenty of examples here in the Forced Induction forum of said brackets
Old Jul 23, 2008 | 08:43 PM
Steve VanS's Avatar
FBody FEAD (Front Engine Accessory Drive) is very compact and easy to get. You can run the short-pulley water pump from the LS2/7 on the FBody FEAD if you pull the pump pulley forward about 3/8" and use a CTS-V belt tensioner with a couple washers between it and the pump casting.
Old Jul 23, 2008 | 10:14 PM
NMCA Scott's Avatar
Thanks for the input gang.
Old Jul 24, 2008 | 11:20 AM
Carshopinc.com's Avatar
LS1TECH Sponsor
we sell our alt only combo, I do understand that you are not wanting to spend alot..... but it's a option...
http://carshop.carshopinc.com/produc..._id/88927/9998
Old Jul 24, 2008 | 02:30 PM
NMCA Scott's Avatar
[QUOTE=Carshopinc.com;9797862]we sell our alt only combo, I do understand that you are not wanting to spend alot..... but it's a option...
H'mmmm. Now that looks like a nice piece.
