Temp Sensor Location Options
Old Jul 30, 2008 | 09:52 AM
SMAX's Avatar
Originally Posted by phatbudde
I did the same as dsrour. Easy access and a true reading at the thermostat
How consistant is your temp in this location? I would think a temp reading from the head or block would be more vital and consistant than a reading on the pump outlet.
Old Jul 30, 2008 | 09:59 AM
veee8's Avatar
Agreed, in the the head, closer to the combustion chamber will give you the most valuable info.
Old Jul 30, 2008 | 11:18 AM
thunderstruck507's Avatar
then I am confused...my 99 harness has a plug for both
my 98 ls1 didnt have one of them (2 wire in front driver head) so I just bought one
Old Jul 30, 2008 | 11:55 AM
bczee's Avatar
The 99 F-Body should only have one Temp sender in the harness, Front Driver side.. are you sure your not mistaking it for some other connector ? AC pressure is near that area.. as is the Crank sensor (rear passenger side).
If you do have to temp sensor, someone must have modified and added a aftermarket on on the rear passenger side.
Old Jul 30, 2008 | 11:58 AM
SMAX's Avatar
Maybe you are confusing it with the oil pressure sending unit connector?
Old Jul 30, 2008 | 06:35 PM
that one is up top behind the manifold though correct?
I had everything mocked up and it plugged into a sensor on both heads, weird....its a factory style plug
Old Jul 30, 2008 | 07:24 PM
veee8's Avatar
I remember the LT1's having 2 sensors. 1 for PCM, 1 for the gauge.
Old Jul 30, 2008 | 11:51 PM
thats how my dad thought these were, so I didn't think anything of it until I read on here there was only supposed to be 1
I need a spot to put a sensor for my factory temp gauge and also a place for my fan turn on since my electric fans are done independently from the ecm, looks like I can tap a head for my gauge and the water pump for the fans
