where does this wire belong?
Old Jul 29, 2008 | 06:54 PM
blackesteyes8696's Avatar
Default where does this wire belong?
The car is a 95 Z with a 98 LS1, automatic, and wired by Speartech. On connector c210 LS1 side, all thats there from speartech is an orange wire to power the PCM. The purple starter wire and ground on this connection is wired in directly to each other so those are ok how they are. and of course the gray wire for prime fuel pump(which i guess isn't needed for the swap). My concern is that orange wire.... Its not going to anything from the LT1 side in the connector. What is it suppose to go into? Car starts and runs but is currently having issues with starting out in 3rd gear. Trying to figure if this wire is causing that and where it goes.... Thanks!
