Vette regulator PSI..
Old Jul 31, 2008 | 07:36 AM
Old Geezer's Avatar
Question Vette regulator PSI..
For those that are using the Vette, external reg/filter on thier conversions:
NE1 have fuel pressure readings, once the swap is completed?
Old Jul 31, 2008 | 08:00 AM
blazin's Avatar
Right now I got mine in and primed the pump manually just using a booster pack and it took awhile but it got up to 51 or 52 psi. Im hoping itll get closer to 60 when I get the motor running on the cars charging/battery system.
Old Jul 31, 2008 | 09:31 AM
bczee's Avatar
I have a Walbro 255 pump.. and the 99+ Vette Filter/Regulator.. at Prime and idle.. it is 57 lbs .....
Old Jul 31, 2008 | 09:50 AM
69LT1Bird's Avatar
Thats the same setup I currently have and I am also at 57psi
